IDN to EIA/TIA-568-A Patch Cable
The figure below shows a diagram of the patch cable used to build an IDN network using STP Category 5 or better cabling. The Cable Requirements section contains more information.
Figure 34-7 IDN to EIA/TIA-568-A Conversion Cable Diagram
Parent topic: Hook-Up Cables
