8-Pin to 6-Pin Hook-up RS422 Cable
The figure below shows a diagram of the patch cable connected between a workstation IDN or RS422-A/RS422-B port to a printer IDN port or 6-pin modular jack on a wall plate.
Figure 34-6 Workstation to Printer IDN Hook-up Cable Diagram
Parent topic: Hook-Up Cables
