6-Pin Modular Connector
This six-pin keystone style modular connector terminates the in-wall wiring at each IDN device in the system. Included in the same package is the connector cap. Cable termination is completed by inserting the conductors and the shield or drain wire into the cap and forcing the cap onto the pins of the connector.
Parent topic: Traditional MICROS RS422 Cabling and Connection Hardware
