Wall Plate
This wall plate mounts to a standard 4x4 metal or plastic conduit box with a plaster ring purchased by the installer. Four screws are provided to mount the plate to the box. To install modular connectors, you must first remove a plastic “knock-out,” then snap the connector into place.
Parent topic: Traditional MICROS RS422 Cabling and Connection Hardware
