31 Integrated Device Network (IDN) Installation
The following sections describe how to install a network of MICROS Integrated Device Network (IDN) printing devices supported by all Oracle MICROS application software.
In most cases, IDN printer(s) are driven by the RS422-A/RS422-B or IDN port of a Workstation.
The following methods are used to connect IDN devices:
The first method makes use of what we call the ‘traditional’ MICROS IDN connection hardware, combined with MICROS approved in-wall RS422 cabling.
The second method utilizes a custom MICROS IDN to Ethernet Patch Cable to build an IDN based on shielded cable and connection hardware. This cabling method is installed and certified by cable contractors in the same manner as Ethernet cabling.
Additionally, Ethernet Printer modules are available (sometimes referred to as ‘IP’ printers). Printers equipped with Ethernet Modules are connected to the LAN like any other Ethernet Device, requiring a Category 6 or better faceplate and patch cable.
