Recommended Cables for a MICROS RS422 ION Network
This sections lists the specifications for the RS422 cabling used for IDN printing devices. For sites not using metal conduit, ensure the cable is shielded appropriately. It is also acceptable to use a shielded Category 6 or better cable.
The following cables are recommended for MICROS RS422 IDN Networks:
Shielded RS422 Cable (MICROS PN 300319-036-PT)
Unshielded RS422 Cable (MICROS PN 300319-001-PT)
The following cables are MICROS-approved RS422 IDN equivalents:
Shielded Cable with PVC Insulation:
Belden 9829
Olympic 3929
Manhattan 3980
Carol C0829
Shielded Cables with Teflon Insulation:
Belden 89855
Berk Tek 256133
Olympic 6173T
Non-Shielded Cables with PVC Insulation:
Belden 8444
Olympic 2998
All CAT6 or better UTP or STP cable that meets the ANSI/EIA/TIA- 568-A/B specifications and has a PVC jacket.
Non-Shielded Cables with Teflon Insulation
Belden 89729, 88444
Olympic 2998T
All CAT6 or better UTP or STP cable that meets the ANSI/EIA/TIA- 568-A/B specifications and has a Teflon jacket.
Parent topic: Integrated Device Network (IDN) Installation
