Order Confirmation Controller (OCC) Features
Table 18-1 Order Confirmation Controller Features
| Feature | Specifications |
Display |
Local VGA and or Remote Display Unit |
Case Material |
Sheet Metal |
Physical Dimensions |
The Order Controller Equipment Dimensions section contains more information. |
Shipping Weight |
7.7 lbs. (3.5 Kg) |
USB Port |
2 |
Serial Port |
1 RS485 Half-Duplex Serial Channel to Remote Display Unit |
LAN Interface |
10/100/1000 Mbps Ethernet - Modular RJ45 |
AC Input Voltage |
Universal Input - 85 to 264VAC, 47 to 63 Hz. |
Input Power |
13W Typical |
Operating Temperature |
0°C (32°F) to 45°C (113°F), 90@ relative humidity max |
Storage Temperature |
-25°C (-13°F) to 80°C (176°F) |
Parent topic: Order Confirmation System
