Remote Display Unit Features and Requirements
Table 18-2 Remote Display Unit Features
| Feature | Specifications |
Display |
15” (1024x768) TFT High-Bright LCD, 262K Colors Max |
Case Material |
Aluminum 5052 |
Physical Dimensions |
The Order Confirmation Remote Display Equipment Dimensions section contains more information. |
Shipping Weight |
23.25 lb. (10.7 Kg) |
Serial Port |
1 RS485 Half-Duplex Serial Channel to OCC. |
LAN Interface |
None |
Input Power |
120VAC +/- 10%, 47 to 63Hz The RDU Heater and Pedestal Fans are 120 VAC Only |
Operating Temperature |
-20°C (-04°F) to 65°C (149°F), 90% Relative Humidity Max |
Storage Temperature |
-25°C (-13°F) to 80°C (176°F) |
Parent topic: Order Confirmation System
