10–Inch Customer Display
The 10–Inch Customer Display shows transaction totals and status. When a check is paid, the display shows the amount tendered and any change due. The 10–Inch Customer Display is compatible with the Oracle MICROS Workstation 6 Series.
Both high-mount and pole displays are available.
Table 21-1 Technical Specifications for the 10–Inch Customer Display
| Feature | 10-Inch Customer Display |
Display Resolution |
Up to 1280 x 800 @ 60Hz |
Aspect Ratio |
16:10 |
Viewing Angle |
Horizontal: ±85° or 170° total / Vertical: ±85° or 170° total |
Input Voltage |
12VDC +/- 5%; 100-240VAC, 50/60Hz |
Assembled Dimensions and Weight |
10-Inch Customer Display with Pole Mount: 22 x 10.02 x 3.65 in/ 558.8 x 254.5 x 92.71 mm; 3.63 lbs/ 1.65 kg 10-Inch Customer Display with High-Mount: Up to 14.25 x 15.5 x 16 in/ 361.95 x 393.7 x 406.4 mm; adds ~1.75 lbs/ 0.79 kg to workstation/stand weight |
Temperature and Humidity |
Operation: 0°C to 40°C / 32°F to 104°F; Humidity: 20% to 80% |
Parent topic: Peripheral Devices
