Customer Display
The customer display shows transaction totals and status. When a check is paid, the display shows the amount tendered and any change due.
Both integrated and pole displays are available.
- Series 1 Integrated and Pole Displays:
- Series 1 displays are supported by the Workstation 5, 5A, PCWS 2015, and KW270.
240x64 STN Graphics capable LCDs with 2x20 emulation mode text capability.
Series 1 Integrated or 6 inch pole mounted Protégé Customer Display System:
The Protégé is an intelligent customer facing display based on a 7 inch 800x400 Color LCD.
The Protégé is compatible with many current workstations.
Series 2 Integrated and Pole Displays:
Matches the colors and styling of the MICROS Workstation 6, MICROS Tablets, and MICROS Base Stations. The following displays are available.
2x20 Text LCD.
Series 1 and 2 Integrated Customer Displays:
Both are supplied assembled with the appropriate mounting bracket.
The Series 1 Pole displays are available in sizes of 6 and 18 inches.
The Series 2 pole display is available in a size of 18 inches.
The Series 1 and Series 2 pole display bases use the same hole-pattern. Mounting hardware is not supplied.
The APG 4000 Series Cash Drawers include the customer display base hole-pattern.
Parent topic: Peripheral Devices
