MICROS Workstation 4 LX Features
Table 16-1 MICROS Workstation 4 LX Features
| Feature | Specifications |
Processor |
AMD LX800 |
Display |
Standard 800 x 600 12.1”TFT color LCD touchscreen |
Operating System |
Windows Embedded CE 6.0 |
Memory |
256M DDR333 DIMM |
Case Style |
Standard Low Profile or Optional Adjustable Stand |
Case Material |
PC-ABS Plastic |
Weight |
7.7 lbs. (3.5 kg) / Shipping Weight 11 lbs. (5 kg) |
Physical Dimensions |
The Equipment Dimensions for the Workstation 4 LX section contains more information. |
Optional Customer Displays (Series 1) |
Integrated or Pole 240x64 STN Graphics Capable LCD Integrated or Pole Protégé Customer Display System |
Cash Drawers |
2 MICROS 4-Pin DIN Connectors - +12V or +24V selectable in the BIOS. |
COM Ports |
USB Ports |
4 |
LAN Interface |
On Board Mbps 10/100/1000 - RJ45 |
Input Voltage |
Universal Input - 85 to 264VAC, 47 to 63Hz. |
Input Power |
23W Typical, 65W Max |
BTU/Hour |
80 Typical, 222 Maximum |
Operating Temperature |
0°C (32°F) to 45°C (113°F), 90% relative humidity max. |
Storage Temperature |
-24°C (-13°F) to 80°C (176°F) |
Parent topic: MICROS Workstation 4 LX
