14 MICROS Workstation 5A
The Workstation 5A is a fan-less Windows Embedded CE 6.0 client and is also capable of running POSReady 2009. Based on the same casework as the WS5, it uses a System Board with an Intel Atom N450 Processor for improved performance. The Operator LED is white to distinguish the 5A from the original Workstation 5 blue. The figure below shows the low-profile workstation and the workstation installed on an optional adjustable.
The Workstation 5A Setup Guide provides instructions for the setup and operation of the Workstation 5A hardware.
