MICROS Workstation 5A Features
Table 14-1 MICROS Workstation 5A Features
| Features | Specifications |
Processor |
Intel Atom N450, Single Core, 1.6GHz |
Display |
Standard 1024x768 15” TFT Color LCD |
Operating System |
Windows CE 6 or POSReady 2009 |
Memory |
2 SO-DIMM Sockets - Max 2 GB DDR2 667 |
Case Style |
Standard Low Profile or Optional Adjustable Stand |
Case Material |
PC-ABS Plastic |
Weight |
10.5 lbs. (4.7 kg) / Shipping Weight 14.0 lbs. (6.35 kg) |
Physical Dimensions |
The Equipment Dimensions section contains more information. |
Optional Customer Displays (Series 1) |
Integrated or Pole 240x64 STN Graphics Capable LCD Integrated or Pole Protégé Customer Display System |
Cash Drawers |
2 MICROS 4-Pin DIN Connectors - +12V or +24V selectable in BIOS |
COM Ports |
USB Ports |
Four IO Panel USB 2.0 Ports (can be disabled) |
Powered USB Ports |
One MICROS Powered USB Port (+5V, +12V, +24V) |
LAN Interface |
On Board 10/100/1000 Mbps Ethernet - RJ45 |
AC Input Voltage |
Universal Input - 85 to 264VAC, 47 to 63Hz. |
Input Power |
24W Typical |
BTU/Hour |
83 Typical |
Operating Temperature |
0°C (32°F) to 45°C (113°F), 90% relative humidity max. |
Storage Temperature |
-25°C (-13°F) to 80°C (176°F) |
Parent topic: MICROS Workstation 5A
