MICROS Workstation 610/620/650 Features and Specifications
Table 7-1 Technical Specifications for the MICROS Workstation 610, 620, and 650*
| Feature | 610 | 620 | 650 |
Processor |
Intel Atom E3827 Dual-Core Processor with 1.75GHz Clock Speed |
Intel Celeron 3765U Dual-Core Processor with 1.9GHz Clock Speed |
Intel i5-5350U Dual-Core Processor with 1.8GHz Base and 2.9GHz Turbo Maximum Clock Speed |
Display |
15.6 inch Widescreen High Definition (1920x1080 FHD) Display Multi-Touch Projected Capacitive Touchscreen High Definition 2nd Display Output Connector Connector for a Second Display Output |
Memory |
2 SODIMM Sockets; DDR3L 1333MHz up to 8GB |
2 SODIMM Sockets; DDR3L 1600MHz up to 16G |
Storage |
32 GB or 64 GB MO-297 Slim SATA 2.0 Solid State Drive Standard SD Card Socket |
128 GB M.2 SATA 3.0 Solid State Drive Standard MO-297 Slim SATA Solid State Drive (Optional) MO-300 mSATA Solid State Drive Socket (Optional) |
256 GB, M.2 SATA 3.0 Solid State Drive Standard MO-297 Slim SATA Solid State Drive (Optional) MO-300 mSATA Solid State Drive Socket (Optional) |
Operating System |
Microsoft Windows Embedded 8.1 Industry Pro (32-bit only) Microsoft Windows 10 IoT Enterprise (64-bit only) |
Magnetic Card Reader |
Modular Integrated 3-Track Magnetic Card Reader; Capable of Hardware Encryption at the Swipe |
2 Configurations Available:
Audio |
Intel HD Audio 2 Integrated Stereo Speakers Standard Headphone Output/MIC Input on I/O panel |
Network |
10/100/1G RJ45 Ethernet 802.11 a/b/g/n Dual Band Radio w/Bluetooth 4.0 (Optional) |
USB |
9 Total:
10 Total:
Serial Ports |
4 Total Standard:
3 Total Standard:
Adjustable Stand Expansion Modules (Optional) |
Powered USB Expansion Module:
Cash Drawer Ports |
2 - MICROS Series 2 Cash Drawer Ports 12/24V Selectable |
Customer Display Port |
1 - Customer Display Port |
Power Output |
1 - 12V Power Out (2.5A) |
Expansion Ports |
1 - MICROS Expansion Port 1 - Mini PCI Express Port |
1 - MICROS Expansion Port |
Power Supply |
Universal Input Auto Switching Power Supply in Adjustable Stand External Universal Input Auto Switching Power Supply for Wall or VESA Mount |
Weight |
Head Unit: 7 lbs Adjustable Stand: 5 lbs |
Dimensions |
322mm x 398mm x 330mm The Equipment Dimensions section contains more details. |
Operating Temperature and Humidity |
0 °C (32 °F) to 50 °C (122 °F) 90% Max Relative Humidity (Non-Condensing) |
Enclosure |
Combination of Cast Aluminum, Rugged PC-ABS Plastic Blend, and PC +10% Glass Fiber Spill Resistant Enclosure Passive Cooling (No Fans) |
Certifications |
FCC Class A, UL, CE, TUV, RoHS, China RoHS |
*The Workstation 6 Series does not contain a camera. The front-facing opening on the Workstation 6 Series touchscreen border was designed for a front-facing camera; however, this cameras was never implemented.
Parent topic: MICROS Workstation 610, 620, and 650
