MICROS Workstation 610/620/650 Primary I/O Ports
12V Power Output
12V Power USB Header
IDN Port RS422/RS232
Series 2 Cash Drawer x2The Series 2 ports are more compact than the previous generation and feature an expanded number of pins to accommodate more options on the cash drawer interface. You can use an adapter cable for backwards compatibility to existing cash drawers.
USB 2.0 x2
High Definition 2nd Display Output Connector Display Output
Customer DisplayThe Customer Display port supports existing pole displays and the Workstation 6 integrated customer display.
USB x2
10/100/1G Ethernet
24V Power USB (620 and 650 Only)
RJ-45 Powered Serial (0/5/9/12V)
2 available on the 610
1 available on the 620 and the 650
RJ-45 Serial
Microphone In/Headphone Out
Figure 7-2 Primary I/O Panel of the MICROS Workstation 610
Figure 7-3 Primary I/O Panel of the MICROS Workstation 620 and 650
Parent topic: MICROS Workstation 610, 620, and 650
