Basic Troubleshooting
The following table contains descriptions and solutions for common problems encountered when installing or operating the Workstation 625 and Workstation 655.
Table 12-1 Basic Troubleshooting
| Problem | Possible Causes | Solution |
The workstation does not start and does not show the splash screen. |
No power to the workstation. |
Make sure you connected the AC power cable to the workstation and to a surge-protected outlet, UPS, power conditioner, or wall outlet. If you placed the workstation on the stand, make sure you connected the power cable to the stand. |
The workstation does not start and the screen remains blank after 30 seconds. |
Missing or defective SO-DIMM. |
Re-seat SO-DIMM 0. |
The workstation does not start. The operator LED stays off or stays on. The operator LCD remains blank after 30 seconds. |
The system board may be defective. |
Contact your Oracle MICROS representative. |
The workstation does not connect to the Local Area Network. |
The Network Patch cable is not connected. |
Install the appropriate patch cable between the workstation and the wall jack. |
The workstation does not read mag cards. |
The mag card reader head is dirty or contaminated. The mag card reader is defective. |
Use the mag card cleaning kit on the reader. Replace the magnetic stripe reader. |
