Performing a System Recovery with Microsoft Windows 10
- Swipe left from the right edge of the touchscreen or move your mouse to the top-right corner of the start screen.
- Select All Settings.
- On the Windows Settings screen, select Update & Security, and then select Recovery from the list of options on the left panel.
- On the Recovery screen under Advanced Startup, select Restart now.
- Select Troubleshoot, and then select Factory Reset. The workstation reboots into a Command shell.
- When the message “The selection will reset the Windows partition [NVMe] to factory default. Are you sure to continue? (Y/N)” appears, type y, and then press Enter. The recovery process begins.
After the recovery process completes, the workstation reboots
to the Windows Out-of-Box-Experience.
