Performing a Factory Reset from BIOS (Microsoft Windows)
This method applies to all 625/655 workstations running Microsoft Windows. To perform system recovery from the BIOS:
- Power on or restart the workstation.
- Enter the BIOS.
- Tap the lower left or lower right portion of the bootup screen to enter the BIOS Configuration Utility
- Tap the Oracle Workstation option.
- From the list of options on the left scrolling panel, select Factory Recovery, and then select Enabled from the drop-down list.
- Tap Home.
- Tap Save and Exit, tap Exit Saving Changes, and then tap Yes to confirm. The workstation restarts automatically.
- On the Choose an Option screen, tap Troubleshoot.
- For the 610:
- On the Troubleshoot screen, tap Factory Reset.
- Type y to reset the Windows partition to the factory default.
When the restoration completes and the workstation restarts,
you can begin the operating system setup.
