Performing a Factory Reset from BIOS (Oracle Linux for MICROS)
This method applies to all 625/655 workstations running Oracle Linux for MICROS. To perform system recovery from the BIOS:
- Power on or restart the workstation.
- Enter the BIOS.
- Tap the lower left or lower right portion of the bootup screen to enter the BIOS Configuration Utility
- Tap the Oracle Workstation option.
- From the list of options on the left scrolling panel, select Factory Recovery, and then select Enabled from the drop-down list.
- Tap Home.
- Tap Save and Exit, tap Exit Saving Changes, and then tap Yes to confirm. The workstation restarts automatically.
- The workstation reboots and the “Entering Recovery Mode” message appears.
- When the “The system will reset Oracle Linux to Factory Default……Are you sure to continue? (Y/N)” message appears, type y, and then press Enter.
- The recovery process begins.
When recovery completes, the workstation reboots to the Oracle
Linux mini-setup.
