Workstation 820 System Unit Basic Features
The Workstation 820 System Unit includes the following basic features.
Oracle MICROS offers the Workstation 820 in multiple configurations. Depending on the configuration, your workstation may not include some of the features described in this document.Figure 2-1 Workstation 820 System Unit Basic Features
Table 2-1 Oracle MICROS Workstation 820 System Unit Basic Features
| Feature | Description |
1. RFID scan area (optional) |
Reads MICROS Contactless Employee ID Cards for employee sign in. |
2. Power button |
The Workstation 820 features a capacitive touch power button that does not depress. When turning the workstation on or off, simply touch the button lightly for the proper duration. There is no need to push the button with force.
3. Stand mounting posts |
Allows you to mount the workstation on Workstation 8 Series stands. |
4. Power In, Network, USB (CFD) |
Ports for power, networking, and peripherals, including the 7-Inch Customer Facing Display. |
5. Stand Information Contacts |
Contact points used to transmit stand-specific information, including part and serial numbers. |
