Technical Specifications
Table 2-3 Technical Specifications for the MICROS Workstation 820
Feature Description
Processor*
Intel Celeron J6413 Quad-Core
Graphics*
Intel UHD Graphics
Display
14- inch FHD (1920x1080p) on-cell touchscreen with 250nit brightness and anti-glare coating
Memory*
8GB
Storage*
  • 256GB SSD (Workstation 820 with Microsoft Windows)
  • 128GB SSD (Workstation 820 with Oracle Linux for MICROS / Linux 7)
Operating System
  • Microsoft Windows 10 IoT Enterprise LTSC 2021 64 bit
  • Microsoft Windows 11 IoT Enterprise LTSC 2024 64 bit
  • Oracle Linux for MICROS (Linux 7)
  • Oracle Linux for Simphony (Linux 9)
RFID (optional)
Integrated RFID reader for employee sign in. Reads 125 kHz and 13.56 MHz RFID tags.
Audio
Basic audio confirmations. HD Audio, single speaker.
Network
  • 1 - Network port. (Requires Ethernet adapter cable for Oracle MICROS Workstation 8 Series for direct connection to Ethernet port)
  • Wi-Fi (optional): Intel Wi-Fi 6E AX210 (Gig+) 802.11ax Tri Band 2x2 160MHz channels, BT5.3
USB
  • 1 - USB power input
  • 1 - Custom low-profile GbE port
  • 1 - USB CFD (Customer Facing Display) port with DisplayPort support
The Peripheral Expansion Module (optional) includes the following ports:
  • 1 - Ethernet
  • 5 - USB
  • 1 - IDN
  • 1 - Serial
  • 2 - Cash drawer
Power Supply
Compatible with the Workstation 8 Series power supply.
Supported Stands
Vertical Stand, Low Profile Stand
Weight
1.09 kg / 2.4 lbs
Dimensions
  • Workstation only: 329.11mm x 215.79mm x 17mm (12.95 x 8.49 x 0.67 inches)
  • Workstation with Vertical Stand: 329.11mm x 289mm x 182mm (12.95 x 11.38 x 7.17 inches)
  • Workstation with Low Profile Stand: 329.11mm x 100mm x 296mm (12.95 x 3.94 x 11.65 inches)
  • Workstation with Low Profile Stand and Customer Facing Display: 329.11mm x 100mm x 314mm (12.95 x 3.94 x 12.36 inches)
All measurements are approximate.
Operating Temperature and Humidity
0 °C (32 °F) to 50 °C (122 °F); 90% Max relative humidity (non-condensing)
Enclosure
  • IP Rating: Workstation 8 System Unit: IP54. When used with the optional Peripheral Expansion Module: IP34.
  • All-aluminum casework provides passive system cooling (no fans)
Certifications
FCC Class A, UL, CE, TUV, RoHS, China RoHS
*The Workstation 820 enclosure is non-serviceable. Internal components cannot be upgraded.
