Workstation 820 Port Power Considerations for Peripheral Devices
The following table lists the Workstation 820 IO ports and the power consumed by each port, depending on BIOS or Diagnostics Utility configurations. Use the table when considering peripherals. Note that some ports do not accept peripherals.
Table 6-2 Workstation 820 Port Power Specifications
| Port or Connector | Available Power Capability |
Power In |
Accepts the Workstation 8 Series power supply only. |
Network |
Accepts the Ethernet adapter cable for Oracle MICROS Workstation 8 Series only. |
USB (CFD) |
Auto-switching power delivery up to 15V 3A. Supports the 7-Inch Customer Facing Display. |
