Workstation 8 Series Stands and Mounts
Figure 4-1 Location of the Release, Lock/Unlock, and Stand Information Contacts on a Workstation 8 Series Stand
Table 4-1 Release, Lock/Unlock, and Stand Information Contacts
| Feature | Description |
1. Release ![]() |
Press the Release button with the Oracle 2.5mm hex key or equivalent to release the workstation from the stand. Note: Secure the workstation when pressing the Release button to prevent sudden drops. If the workstation does not release from the stand, insert the Oracle 2.5mm hex key or equivalent into the Lock/unlock socket, turn counterclockwise, and then press the Release button. |
2. Lock/Unlock ![]() |
Note: Use of the Lock feature is optional.Lock: Insert the Oracle 2.5mm hex key or equivalent into the Lock/Unlock socket and turn clockwise to lock the workstation. Unlock: Insert the Oracle 2.5mm hex key or equivalent into the Lock/Unlock socket and turn counterclockwise to unlock the workstation. Note: To release the workstation from the stand after unlocking it, press the Release button. |
3. Stand Information Contacts ![]() |
When paired with any Workstation 8 Series workstation, the stand information contacts transmit stand-specific information, including part and serial numbers. |
