The Oracle 2.5mm Hex Key
Oracle provides a 2.5mm hex key with many Workstation
8 Series hardware products. The hex key lets you perform a number
of important tasks such as locking and unlocking a workstation/stand
assembly, releasing the workstation from a stand, tightening/loosening
stand captive screws, and mounting/unmounting peripherals.
Figure 4-2 Oracle 2.5mm hex key
Storing the Oracle 2.5mm Hex Key
Workstation
8 Series stands include a storage slot in the cable organizer for
a single Oracle 2.5mm hex key, as shown below.
Figure 4-3 Hex key storage slot on Workstation 8 Series stands
