Customer Facing Display for Vertical Stand
Choose the location (left or right) on the Vertical Stand to mount the Customer Facing Display.
Place the Customer Facing Display assembly against the Vertical Stand base, aligning the captive screws with the corresponding holes in the stand.
Place the cable in the notch in the Vertical Stand base, and then tighten the Customer Facing Display captive screws with the MICROS 2.5mm hex key or equivalent.
Figure 5-1 Mounting the Customer Facing Display on the Vertical Stand
Connect the cable to the Workstation 820 USB(CFD) port.
If you are adding a Customer Facing Display to an existing Workstation 8 Series configuration with a Peripheral Expansion Module, connect the cable to the Peripheral Expansion Module USB(CFD) port.
