Credit Card Tender Media
- In the EMC, select the enterprise, click Configuration, and then Tender/Media.
- From Insert Record:
- Configure the following fields:
Select Record Number or Range: refer to the table below or you can use records that already exist.
Record Name: refer to the table below.
- Click OK.
- Double click the row header for the new record.
- From the General Tab, configure
Privilege Group: 0
Key Type: 1 – Payment
NLU: 0
Report Group: Credit Cards
SRM Payment Type: 0 – None
- From the Options Tab, configure
Printing Tab. The settings here are not required for SPI and should be set based on what you need.
Print Customer Receipt: enable
Print Summary Totals: enable
Print Check Trailer: enable
Print Check on Demand: enable
Interface Tab: if not using an interface, then leave all options blank. If using an interface, then configure as necessary.
Credit Card Options
Payment Credit Card Options: all options set to zero
Preambles | Add
Start: refer to table below
End: refer to table below
Option Bit 7–80: disable
Taxing Options. The settings here are not required for SPI and should be set based on what you need.
Ops Behavior
Assume Paid in Full or Amount Required: enable (select one based on your requirements)
Item is Shareable: enable
Charge Tip Options. Enable the following options only if you use tips for credit cards.
Service Charge: select an option
Charge Tip Required: enable for credit card only
Post Amount of Gross Receipts on Tip Report: enable
Post Amount to Charged Receipts on Tip Reports: enable
Miscellaneous Options: leave all options deselected
- Click Save.
Table 6-2 Credit Card Type Reference
Object Number Description Preamble Start Preamble End (leave blank) Preamble Length 11, or previously existing record
Visa
0*
12*
17*
18*
20*
1
2
2
2
2
12, or previously existing record
MasterCard
1*
13*
19*
24*
27*
1
2
2
2
2
13, or previously existing record
AMEX
2*
1
14, or previously existing record
Diners Club
3*
1
15, or previously existing record
JCB
4*
1
16, or previously existing record
Discover
26*
10*
14*
2
2
2
17, or previously existing record
Debit
11*
61*
62*
63*
64*
65*
66*
2
2
2
2
2
2
2
