Tender Media
- In the EMC, select the enterprise, click Configuration, and then click Tender/Media.
- From Insert Record, click Create a Blank Record.
- Configure the following fields:
Select Record Number or Range: refer to the table below or you can use records that already exist.
Record Name: refer to the table below.
- Click OK.
- Double click the row header for the new record.
- From the General Tab, configure
Privilege Group: 0
Key Type: 1 – Payment
NLU: 0
Report Group: Credit Cards
SRM Payment Type: 0 – None
- From the Options Tab, configure
Printing Tab: leave all options deselected.
Interface Tab: leave all options deselected.
Credit Card Options
Payment Credit Card Options: set all options to zero
Preambles: do not add preambles
Option Bit 7–80: disable all option bits
Taxing Options: disable all option bits
Ops Behavior
Assume Paid in Full: enable
Item is Shareable: enable
Charge Tip Options. Enable the following options only if you use tips for credit cards.
Service Charge: select value
Charge Tip Required: disable
Post Amount of Gross Receipts on Tip Report: enable
Post Amount to Charged Receipts on Tip Reports: enable
Miscellaneous Options: leave all options deselected.
- Click Save.
Table 6-1 Reference Table
Object Number Description Preamble Start Preamble End (leave blank) Preamble Length 10
SPI Default
No preamble
No length
