Payments
- In the EMC, select the enterprise, click Setup, and then click Payments.
- From Insert Record:
- Select Desired Object Number Choice.
- Set the Record Name field to SPI.
- Click OK.
- Double click the row header for the new record.
- Click Import from a file.
- Navigate to the EMCClient directory. For example,
C:\Program Files\Oracle Hospitality\EMCClient - Select
Micros.Payment.LoadableCreditCardModule.dllfrom the folder contents. - Click Open.
- Configure the following values:
Driver: SPI
Device: Internal
- From Configuration Tab, configure
the following fields:
Allow Manual Authorization Credit Card: True
Allow Partial Settlement On Batch: True
Data Lifetime Seconds: 7200
Do Not Batch: True
Encrypt Data: False
Incremental Authorizations: True
Log Level: ALWAYS
Manual Card Data Entry Retries: 0
Offline Authorizations: 0
Prompt for Manual Card Data Entry: False
Retry Authorization Reversals on Batch: False
Run as Service: False
- Click Save.
