Payment Drivers
- In the EMC, select the enterprise, click Setup, and then click Payment Drivers.
- From Insert Record:
- Select the desired Object Number.
- Set the Record Name field to SPI.
- Click OK.
- Double click the row header for the new record.
- Click Import from a file.
- Navigate to the EMCClient directory. For example,
C:\Program Files\Oracle Hospitality\EMCClient - Select
OPIPayment.dllfrom the folder contents. - Click Open.
- From Configuration Tab, configure
the following values:
Description: SPI
Do not use spaces
Display Name: SPI
Do not use spaces
Enable Quick Chip: False
Merchant Number: 1
Host Timeout: 120
Include NameSpace with XML Message: False
Primary Host: https://127.0.0.1:8443
This value is established later at each workstation.
SPI Interface: True
Validate XML Message Against Schema: False
Security Settings: use Https with no certificate validation
Return to the Currency Code field.-
Currency Code: enter the appropriate code
840 is the United States dollar and 124 is the Canadian dollar.
- Click Save.
