Guest Check Card Statement Descriptors
Edit the business name on the guest card statement.
The guest card descriptor appears on your guest’s card statement as the name of your business. Use a name that you want your customers to identify you by. If you don’t edit the guest card descriptor, then the Account Holder name that the Account is linked to is used.
Required system privilege: Add/Edit Accounts.
