Configure Terminal to IP Address
  1. Connect the terminal to the internet and then navigate to Admin menu.
  2. If you are using the terminal’s wired (Ethernet) connection, follow the substeps below. If using Wi-Fi, see Step 3.
    1. Tap Network and then Tap Ethernet.
    2. Deselect DHCP.
    3. Enter the IP address, the Subnet mask, the Router, and the preferred and alternate DNS for your network.
      To enter a period (.), click 1 twice.
    4. Tap Apply.
  3. If you are using the terminal’s Wi-Fi connection:
    1. Tap Network and then tap Wi-Fi.
    2. Tap the i symbol for your network and then tapIP setting.
    3. Deselect DHCP.
    4. Enter the IP address, the Subnet mask, the Router, and the preferred and alternate DNS for your network.
    5. Select the check mark to confirm.
