Set IP Address for Verifone e285
  1. Press 9 and then press the green o button to navigate to the Admin menu.
  2. Enter your Admin menu passcode, provided by Oracle Support, and then press the green o button.
  3. From the admin menu, tap Network and then tap Wifi.
  4. In the IP Settings field, deselect DHCP.
  5. Enter the following for the Oracle Restaurants network. To type a period (.), press 1 twice.
    1. IP address
    2. Subnet mask
    3. Default gateway
  6. Tap Apply.
  7. Press the red x button to exit.
  8. Press the red x button to exit the admin menu.
  9. Tap Reboot from the admin menu and confirm.
