Connect Verifone e285 to Network Connect the terminal to a power supply. During startup, the display turns on and off a few times. Tap Configure Network. Tap Wi-Fi. Select Wi-Fi. Tap the + icon to add a network and then complete one of these two options: Select the network from the list and then enter the Wi-Fi password. Tap Add manually and then enter the name (SSID) of the Wi-Fi network and the Wi-Fi password. Tap the check mark to confirm. Parent topic: Verifone e285
