Set IP Address for Verifone P630
- Press 9 and then press the green o button to navigate to the Admin menu.
- Enter your Admin menu passcode, provided by Oracle Support, and then press the green o button.
- From the Admin menu, tap Network and then select your connection type:
- If you are using the terminal’s wired connection, tap Ethernet.
- If you are using the terminal’s Wi-Fi connection, tap Wi-Fi.
- In the IP Settings field, deselect DHCP.
- Enter the following for the Oracle Restaurants network. To type a period (.), press
1 twice.
- IP address.
- Subnet mask.
- Default gateway.
- Tap Apply.
- Press the red x button to exit.
- Press the red x button to exit the admin menu.
- Tap Reboot from the admin menu and confirm.
Parent topic: Verifone P630
