Connect Verifone P630 to Network
- Connect the terminal to a power supply. During startup, the display turns on and off a few times.
- If you are using Ethernet LAN, connect the Ethernet cable to the port marked ETH.
- If you are using Wi-Fi, tap Configure Network.
The terminal sets the network as default automatically and connects to it. You then see a Wi-Fi icon at the top of the display.
To changed the Wi-Fi network, navigate to the Admin menu, click Network, and then click Wi-Fi.Parent topic: Verifone P630
