View/Edit Existing Inventory Counts
To access an inventory count, either click the hyperlink in the Inventory Name column or open the Actions menu at the right side of the table and select View/Edit.
Open counts can be viewed and edited.
Booked counts can only be viewed.
Cancelled counts can no longer be viewed or edited.
View/Edit Open Inventory Counts
Simple View: Also known as a Blind Count, this view displays only the items, units, and an entry field for the counted quantity.
Full View: In addition to the fields available in the Simple View, this view also displays calculated on-hand quantities and deviation values.
Count Details
Inventory Name/ID
Inventory Type
Status
Memo
Functions
Table 6-2 Open Inventory Counts Functions
| Function | Description |
| Close | Closes the current view and returns to the list of counts. |
| Book | Requires permission for Full View. |
| Refresh | Refreshes counted data. This is required when multiple users may enter data for the same location. |
| Calculate Combined Totals | Requires permission for Full View. Available only for inventory counts based on Areas and Shelves definitions where items can be counted multiple times in one location on different shelves. Required to summarize entered data from multiple rows for the same item. |
| Generates a count sheet in PDF format that can be printed. | |
| Add Item | Requires permission to add items. Allows users to add items to the inventory count. |
| Expand All / Collapse All | Allows users to expand or collapse the grouping in the count screen. |
| Sort By | Available for inventory counts based on Item Groups. Allows users to sort items in the list by: Item Group and Item Name, or Item Name only. |
| Filter By | Requires permission for Full View. Allows users to filter items that have deviations or are unassigned. |
| Search | Allows users to search for items by typing keywords. |
| Auto Save | Entered data is saved immediately. If disabled, a Save button is displayed and the user must save the entered data manually. |
Detail Grid
- Simple ViewCount Based on Areas and Shelves
Area
Shelf
Item Name
Unit (1 row per unit, based on inventory count creation)
Counted Quantity: Enter the counted quantity
Total row per item: Auto-calculated
Count Based on Item Groups-
Item Group
Item Name
- Full ViewCount Based on Areas and Shelves
Area
Shelf
Item Name
Current Quantity on Hand: Calculated quantity, filled for Total row only
Current On Hand Value: Calculated value, filled for Total row only
Counted Value: Auto-calculated based on counted quantity
Deviation Quantity: Auto-calculated, based on counted quantity and calculated quantity
Deviation Value: Auto-calculated, based on counted quantity and calculated quantity using the price.
Price: Price of the item per unit
Item Group
Item Name
Deviation Value: Auto-calculated, based on counted quantity and calculated quantity using price.
Parent topic: Inventory Counts
