Developer Tools
Use the Developer Tools to test and maintain legacy import data.
Table 14-2 Developer Tools
Action When to Use Description
Prepare Sideload Test Data
Use this action to convert a successfully staged package import into NetSuite CSV sideload test data.
  • Available only after staging completes successfully and before record mapping begins.
  • Removes the import run association and deletes the original staging reports.
  • Marks the original import run as Aborted.
  • Makes the staged data available as an unassigned sideload candidate in Legacy Import Preflight.
  • Supports only stage types that are compatible with sideload processing.
Full Account Cleanup
Use this action to remove legacy import test data from the current non-production account.
  • Available only in non-production environments.
  • Cleans up data across the entire account and is not limited to a single import run.
  • Cannot be started while an import report is in progress.
  • Removes imported NetSuite records, staging data, reports, and other related legacy import test data.
