Delete Custom Alternate Purchase Units
You can delete only custom Alternate Purchase Unit (APU) records.
Deletion may be blocked in the following situations:
- The APU is used by a saved Purchase Order or Receipt Without PO. A dialog lists the transactions that reference the record and provides a link to each transaction.
- The record is required to support a Preferred APU.
- Deleting, inactivating, or clearing Preferred from the last preferred record would leave the Item and Subsidiary without a preferred vendor. A confirmation message explains the impact before you continue.
A transaction containing the same Item and Unit does not by itself prevent deletion. The transaction must be associated with the custom APU selected using restricted purchase-unit mode.
NetSuite dependent-record validation prevents you from deleting Items or Vendors referenced by an APU. You can make the Item or Vendor inactive, which temporarily suspends the related APU configuration.
- In the Action menu, click Delete for a custom record.
- Review the confirmation, which identifies both the Unit and Item.
- Click Delete to continue, or Cancel to leave the record unchanged.
Parent topic: Maintain Alternate Purchase Units
