PreviousNext
JavaScript must be enabled to correctly display this content
Edit Custom Alternate Purchase Units
In the Action menu, click Edit for a custom
record.
The Vendor, Item, and
Subsidiary fields identify the existing record
and are read-only during editing.
Change the Unit, Price Per Unit,
Vendor Item Number, Discount
(%), Default,
Preferred, and Active
fields.
Click the Save button.
To create the same record for another subsidiary, click Save
As in the Action menu or create a new record. Then delete the
original record only if it is no longer required.
