Unlink Menu Items
- Click Maintenance, and then click Menu Item Linking.
- Use the drop-down lists to filter the results, and then select the relevant Menu Item Name.
- To remove every item and recipe link, click Unlink All, and then click OK.
- To remove only specific links, select the items or recipes, and then click Unlink.
Parent topic: Menu Item Linking
