Import Locations
POS locations are represented as subsidiaries in NetSuite, while POS revenue centers are represented as locations in NetSuite.
Important:
Before importing data from Simphony, be aware that a subsidiary assignment cannot be changed after the subsidiary is created in NetSuite. Therefore, if an imported location should be associated with a child subsidiary rather than the parent subsidiary, you must map the location to the appropriate child subsidiary that has already been created in NetSuite.
