Manage Quick Actions
This function is available only to users with the ORBO Nav Config permission.- Use the All checkbox to switch the view between your own Quick Action links and links created for all other users.
- Click the Manage button to open the Quick Actions management interface.
- Change Categories, Groups, or Shortcuts.
Table 11-1 Categories
Action Description Recreate Default Links Delete all existing Quick Action links and restore the default Quick Action links.
Custom links created manually are preserved.
Add Category Create a new top-level category and define its display order and role permissions.
Use concise category names to improve readability and maximize display space.
Edit Change the category name, description, and display order. Delete Remove a category and all associated groups and shortcuts. Manage Category Groups Access and manage the groups within the selected category. Table 11-2 Category Groups
Action Description Add Group Create a new group within the selected category.
Use concise group names to improve readability and maximize display space.
Edit Change the group name, icon, and display order. Delete Remove a group and all associated shortcuts. Manage Group Shortcuts Access and manage the shortcuts within the selected group. Table 11-3 Group Shortcuts
Action Description Add Shortcut Create a new group shortcut link. Name Enter the display name for the shortcut. Link Enter the URL or NetSuite page path that the shortcut opens. Icon Select an optional emoji icon to display with the shortcut. Tooltip Enter the text to display when users hover over the shortcut. Use descriptive tooltips to help users understand the purpose of each shortcut. Target Specify whether the shortcut opens in the current window or in a new browser tab. Display Order Enter a number to control the sequence of categories and groups. Lower numbers appear first. - Click the Save button to confirm the changes.
- Test all shortcuts after adding or editing them to ensure they navigate to the correct destination.
Parent topic: Quick Actions Portlet
