Disabling DOM-Related Options for KDS Capacity Usage
To use KDS Capacity Scheduling, you need to disable several options related to Dynamic Order Mode (DOM).
  1. Select the revenue center, click Setup, and then click RVC Parameters.
  2. Click the Options tab, and then disable 50 - Enable Dynamic Order Mode (DOM).
  3. Click Save.
  4. Select the revenue center, click Setup, and then click Order Devices.
  5. Double-click the KDS order device record to open it.
  6. Click the KDS tab, and then select 0 - None in the DOM Type drop-down list.
    For each order device that uses KDS Capacity Scheduling, select 0 - None as the DOM Type.
  7. Click Save.
  8. Select the property, click Setup, and then click KDS Displays.
  9. Double-click the KDS Display record to open it.
  10. Click the Display tab.
  11. In the KDS Chit Layout Style field, select an appropriate non-DOM KDS layout (in the 100 or 200 range).
    Some KDS Chit Layout styles are only intended to be used with certain Display Types. KDS Chit Layout Styles contains a detailed list of the chit layout styles.
  12. Click Save.
