Configuring Employee Privileges for Using CAL
To configure CAL with a Simphony release 2.9.1 or higher enterprise, an employee must have role privilege 10065 enabled in the EMC Roles module. Without this privilege and a valid EMC username and password, a user cannot authenticate a client and load Simphony applications through CAL. To configure the privilege in the EMC:
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Identify existing roles or add new roles for employees that need to have this privilege.
  3. Double-click the roles record assigned to the soon-to-be privileged user.
  4. Click the Operations tab, and then click the Miscellaneous subtab.
  5. In the Miscellaneous Options section, select 10065 - Download Software, Install and Authenticate Clients and Service Hosts Using CAL, and then click Save.
  6. Repeat these steps for each role as needed.
    Figure 1-2 Roles Miscellaneous Options
    This figure shows the employee roles module, specifically the option to enable certain users to use the CAL functionality.
