Configuring CAL Package Permissions
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Double-click the role record assigned to the privileged user (for example, administrator, manager, or server).
  3. Click the EMC Modules tab.
  4. Scroll to the Hardware section and search for CAL Packages. Based on your preferences, select the desired checkbox to assign View, Edit, Add, and Delete privileges to the role.
  5. Click Save.
  6. Repeat these steps for each role as needed.
