Upgrading DCAL Workstation from Releases Prior to Simphony 2.9.3
When upgrading a DCAL Workstation running Simphony client releases prior to 2.9.3, the download status of previously downloaded packages is lost and cannot be automatically recovered.
Recommended Workaround:
  1. Remove the DCAL Workstation service from the property prior to the upgrade.
  2. Re-image the workstation using the manufacturer supplied factory recovery mechanism.
    Applies to: All Simphony releases prior to 2.9.3
