Viewing the DCAL File Download Status
After you configure and implement CAL package download schedules, you can review the status of CAL packages that are scheduled to download from the Enterprise to the DCAL server for a selected workstation.
You must have the View privilege for the CAL Packages module. Configuring CAL Package Permissions contains more information.
  1. Select the Enterprise level, click Setup, and then click CAL Packages.
  2. Click the DCAL Status tab.
  3. If there are many workstations, filter by property and obtain information specific to one DCAL server by selecting the appropriate search options:
    For a multi-tenant environment, only the information related to a specific Enterprise is filtered.
    • Install Date From To: Select the date range of the CAL deployment to search.
    • ServiceHost #: Enter the object number of the Service Host to search.
    • ServiceHost Name: Enter the name of the Service Host to search.
    • Property: Select the property to search. The Search button becomes active after you select a property.
    • Status: When enabled, a drop-down list appears. Select All, Started, Failed, or Success to limit the CAL package deployment by status.
    • Platform: When enabled, a drop-down list appears. Select the workstation operating system platforms.
  4. Click the Search button.
    The CAL packages section shows the CAL packages that are available in the database for download, and the corresponding number of files that have been downloaded to the DCAL server.
    The Install Status shows the installation status of the individual CAL client workstations connecting to the DCAL server.
