Configuring an Android Workstation
Perform the following tasks before installing the Simphony software:
  • Configure the Android device to be a member of the POS network using a static Internet Protocol (IP) address.
  • Install antivirus software on the device.
  • Turn off Trusted Sources on the device. See the manufacturer instructions for details.
Complete the following device configuration steps:
  1. Sign in to the EMC and select the property, click Setup, and then click Workstations.
  2. Insert a new workstation record.
  3. Double-click the record to open it in form view.
  4. Enter information in the workstation configuration fields, and set the Type as 6 - Tablet Client.
    If you are configuring a Motorola MC40 device, set the Type as 1 - Mobile.
  5. Enter the Internet Protocol (IP) address or host name of the Service Host where the workstation application runs in the Address/Host Name field.
  6. Click the Options tab, and then click the Display/Security subtab.
  7. Select 39 - Floating Tablet.
  8. (Optional) If you are using a printer with the Android device, configure the printer from the Printers module and set it from the Printers tab. Configuring a Printer contains more information about setting up the printer.
  9. Click the Revenue Centers tab, and then assign the device to a revenue center.
  10. Click Save.
  11. See Installing the Android Service Host for information about installing the Simphony Service Host.
