Creating Menu Tags
A delivery service provider menu is a collection of Simphony menu items. Use a menu tag to associate a Simphony menu item with the delivery provider menu. Each provider must have a unique menu tag in Simphony. Only the menu items with these tags are visible in the delivery provider application.
You need to have the role privilege to view, edit, add, or delete tags. See the Oracle MICROS Simphony Configuration Guide for more information on creating roles and setting privileges for tags in the Roles module, EMC Modules tab.
Simphony retains all tag activity (including add, edit, and delete) for use in auditing.
  1. To create a tag:
    1. Select the Enterprise, click Descriptors, and then click Tags.
    2. Click the insert icon (This image shows the Insert icon, which is a green circle with a white plus sign.) on the toolbar.
    3. Add a new tag record with the appropriate name (for example, Online Only), and then click OK.
      You cannot duplicate tag names.
    4. Click Save.
  2. To edit a tag:
    2. Change the tag name in the Name column.
    3. Click Save.
  3. To delete a tag:
    If you delete a tag that is associated with a menu item definition, the association is also deleted.
    2. Highlight the tag record, click the delete icon (This image shows the Delete icon, which is a red circle with a white X.) on the toolbar, and then click Yes.
    3. Click Save.
  4. To associate a tag with a menu item definition, see the Oracle MICROS Simphony Configuration Guide for instructions.
