Configuring a Bank Deposit Reference Through Extensibility
ECM allows you to define a bank deposit reference through extensibility
using the GetReference entry. Transaction and location information
is exposed to extensibility to set values that you can use (if required)
in the bank deposit reference. The bank deposit reference entry is
based on the following transaction and location information:
Property Number and Name
Revenue Center (RVC) Number and Name
Business Date
Workstation Number
The extensibility application automatically generates the bank deposit reference. When you set the bank deposit reference value through extensibility, the workstation operator cannot enter or edit the reference value.
Related Topics
Parent topic: Enterprise Cash Management
